big_l
| posted on 19/2/11 at 11:22 AM |
Help with brakes sticking on after a quick drive
Hi my brakes keep sticking on after a blast to the point where you can't move the car ?
If you leave it for 10 mins after they gradually un seize them selves ???
It's all four brakes ? Help
Check out my blog mnrvortxhayabusa@blogspot.com
RichardK
| posted on 19/2/11 at 11:29 AM |
Foot pedal binding and not returning properly?
Gallery updated 11/01/2011
RichardK
Push rod too long, dual or single master cyl?
RichardK
| posted on 19/2/11 at 11:32 AM |
Should explain a little, the above can cause the pads to bind slightly and cause them to heat up, as they get hotter and hotter the brake fluid will
boil and expand causing the pads to apply harder making the problem worse, you leave them to cool and the problem goes away, temporaliy.
Rich
Frosty
| posted on 19/2/11 at 12:24 PM |
Jack the front of the car up, press the brakes hard, and then release.
If you now can't turn the front wheels by hand then you have a problem. I would start by disconnecting the master cylinder push rod from the
pedal so you know that the pedal has no influence in pre-loading the push rod for any reason.
See if you can turn the front wheels now?
Benzine
| posted on 19/2/11 at 12:28 PM |
I had this problem when I went for my very first drive, it was the brake pedal that needed adjusting as it was putting on a tiny bit of pressure the
brakes which, over the course of a few miles, caused them to overheat
| posted on 19/2/11 at 03:01 PM |
The pistons in the master cylinders need to be able to return fully, 9 times out of 10 the problem is the stop washer at the pedal end of the master
cylinder not allowing the push rod to return fully.
JeffHs
| posted on 19/2/11 at 03:06 PM |
Or, as in my case. the push rod is too long - fine when cold but all of the clearance disappears when the brakes are hot, so the master cylinder
return port is still closed and it holds the brakes on.
| posted on 19/2/11 at 03:20 PM |
You can try hooking your toe under the brake pedal and pulling it back when this problem happens. If your brakes free off immediately then it's
likely that the pedal isn't returning to its home position fully. The pedal needs to come right back to let excess fluid back into the
reservoir, and if this doesn't happen the pressure will build up a little bit more with every brake application.
Do you have a return spring on your brake pedal? Mine has quite a hefty one that helps to pull the pedal to the 'off' position - with the
power of leg muscles and the leverage in the pedal the spring isn't noticeable at all.
RazMan
| posted on 19/2/11 at 05:46 PM |
Just a longshot here, but have you bled your brakes recently? It could be due to water in the fluid, which boils when the brakes get hot, giving the
kind of problem you are experiencing.
Raz
DRC INDY 7
| posted on 19/2/11 at 07:30 PM |
Brake pedal not enough free play
brake fluid level too high
Puddle Dodgers Club
big_l
| posted on 19/2/11 at 09:18 PM |
I'm away all weekend but I'll try a few things when I'm
Back ...
The strange thing is I can drive it normal for 50 miles no issues but if I go for a blast it does it ????
