2 empty axles free to a good home - pick up only
I suppose I should check before scrapping them
I have 2 spare cortina style axles
Note – these are not the atlas type they are the weaker and not as popular 1600 ones. Atlas diff's including the baby atlas will NOT
fit
I have stripped out the guts leaving only the pinion in place on one of them as I can't be arsed removing that.
One of them had a very good condition diff which I'm keeping and another diff needs rebuilt. All bearings except the good diff are shot so need
replaced. I also have 4 halfshafts that I don't need too.
Someone has also cut off the brackets for the cortina suspension arms and welded on leaf spring mountings instead.
If they are any use to you U2U me, Pick up only as they are too heavy to post
[Edited on 25/2/11 by Mr Whippy]
