Mark Allanson
| posted on 10/3/11 at 07:23 PM |
Tyres Tyres Tyres.....
Its time for a set of 4 for the locost again, I currently run 185 60 13's, but the side walls have started to crack (6 years on the road
though). I want to increase the ground clearance a little and improve the handling (reducing the scrub angle to what Ford intended) so am
contemplating moving to 185 70 13's or even 175 70 13's (which can be bought VERY cheaply)
Any comments/alternatives?
daniel mason
| posted on 10/3/11 at 07:30 PM |
dou you run the same size front and back? there is loads of 205/60/13 but they may be too wide for the front. camskill do a large range of khumo tyres
big_wasa
| posted on 10/3/11 at 07:39 PM |
there is not much in a 70 profile thats also speed rated over 112 mph ish.
matty h
| posted on 10/3/11 at 07:43 PM |
Use this link see what the difference would be.
http://www.etyres.co.uk/tyre-size-calculator.htm
andy188
| posted on 10/3/11 at 08:07 PM |
i had the samee problem last year, im using toyo 350 in 185x70x13, seem ok, not your out and out racer, 140.00 4 4, have heard yokohama ao21 r good
for road use and some track, not that hard wearing though, george polley is the main supplier, circuit boys r getting good results with these, bit
dearer though. hope this helps, andy
Mark Allanson
| posted on 10/3/11 at 08:16 PM |
I can get Avon ZV1's for £29.00 in 175 70 13, but 185's are £41 - will I feel and discernible difference?
