Tigers
| posted on 21/7/04 at 08:44 AM |
Suspension travel - how much?
Hi guys!
Yeasterday I did some CAD drawing again and discovered that with a current placement of shock absorbers suspension movement on front wheels will be
slightly less than 2 inches in each direction (up and down). From your experience - is that enough or not? (Spring rate 375 lbs/in, suspension
leverage ~1.9/1)
Or should I try to place the shocks diferently - but then eaven more suspension leverage will be involved and need for firmer springs....
Any input wellcomed.
Thanx,
Janis
JAG
| posted on 21/7/04 at 11:16 AM |
I've never measured it but +/- 2" sounds about right to me.
Justin
stephen_gusterson
| posted on 21/7/04 at 11:20 AM |
4 ins travel sounds normal - but i have heard it expressed as a 1 inch droop, 3 inch compress...........
atb
steve
pbura
| posted on 21/7/04 at 11:32 AM |
AFAIK, usual practice is to split the shock travel 2/3 for bump and 1/3 for droop. However, the shock should bottom in bump before your
suspension.
One installation guide I saw said to include the bump stop in the total shock travel, but I'm not so sure about this. Seems like the best of
all worlds would be to have 2" of travel before hitting the stop, then bottom the rubber before bottoming the suspension. I don't think
any car has that much wheel travel, though.
Pete
Pete
Tigers
| posted on 21/7/04 at 12:15 PM |
Thanx guys, this makes me less worried
stephen_gusterson
| posted on 21/7/04 at 12:21 PM |
most cars have no bump stop capability - on my car the total upward travel is summat silly - like 6 - 8 ins - before the transit top link hits its
limit.
The shocker will I think bottom before this total mechanical travel is reached. It would have to be some mother of a pot hole tho!
atb
steve
locost_bryan
| posted on 22/7/04 at 03:27 AM |
like the one Gronholm hit in Argentina
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
NS Dev
| posted on 22/7/04 at 09:16 PM |
surely with 6-8 ins travel the spring will go coilbound? Maybe not depending on shocker angle but must be a very long spring if not!
stephen_gusterson
| posted on 22/7/04 at 10:31 PM |
i was talking of mechanical travel with no shocker.... ive not guestimated or measured how far the coil will allow. Its 350lb so I guess its not gonna
compress all the way. Id rather it went coilbound than broke the top joint by forcing it past its travel.
atb
steve
