alfasudsprint
posted on 22/7/04 at 08:20 PM |
bent wheel question
hi all,
i am temporarily using the steel wheels from donor, had them painted, went to put tyres and baçance, couldn't balçance due to poor condition of
wheels...I had tried to repair but are a bit out , need a pro job they said.
So, question is, would it be unsafe/stupid to drive like that for a short time at limited speeds?
NS Dev
posted on 22/7/04 at 09:13 PM |
how bent are they? As long as the bead seating area is ok then there should be no problem. We have run alloys with chunks of rim broken off on a rally
car through the forest before with no problems!
Also, are the balancing centre fobbing you off? A good whack with a copper lump hammer can take a pretty bad dint out of a wheel, certainly enough to
balance it.
alfasudsprint
posted on 23/7/04 at 12:21 AM |
pretty bent but not a disaster...will post a pic later if I can work the picture attachment...thanksbtw
