renniep
posted on 17/7/11 at 07:33 PM |
FWD Hubs
Am I being dim or is there any reason why I couldn't use FWD hubs from a Focus or Mondeo on a "standard" Locost. Would you not just
blank the drive shaft hole either by cutting a drive shaft splined end and tack weld in to place or plate over and weld?
RennieP
adithorp
| posted on 17/7/11 at 07:48 PM |
No reason why not. Thats what Rover did with the MGF.
You'd just use the outer section of the CV joint though. No welding required; just push it through and tighten the nut (you need it to hold the
bearing together).
http://jpsc.org.uk/forum/
| posted on 17/7/11 at 07:55 PM |
The main problem is the rack sits behind the uprights on pretty much all FWD cars, which means the steering rack goes right through the engine
compartment in a Locost.
b14wrc
| posted on 18/7/11 at 11:10 AM |
Not so much a problem if your car is going to be mid engined?!?
20vt powered rear engined locost
Doctor Derek Doctors
| posted on 18/7/11 at 12:29 PM |
RennieP
The RWD 911's do pretty much this, they use the same hub as the 4wd versions but with just a stub shaft instead of full driveshafts. (or they
used to anyway)
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
