Author: Subject: Diassembling rear beam off the car
PSpirine
posted on 26/7/11 at 09:49 PM Reply With Quote
Main question is - how does one undo the rear driveshaft hub nuts when the beam is off the car?
Thanks,
Pavs
matt_gsxr
posted on 26/7/11 at 10:08 PM Reply With Quote
Airtool is easiest.
Alternatively you can put the driveshafts in a vice, but make sure it needs to be pretty solid.
austin man
posted on 26/7/11 at 10:11 PM Reply With Quote
chisel works if all else fails as does a grinder and chisel
blakep82
posted on 26/7/11 at 10:20 PM Reply With Quote
impact wrench never fails for this sort of thing
________________________
PSpirine
posted on 26/7/11 at 10:26 PM Reply With Quote
Thanks chaps, will give the impact gun a go. Although all I've got is an Aldi jobbie and struggles with wheel nuts! Will also try the breaker bar and just shock it.
Could someone confirm which one is left-hand threaded?
Macbeast
posted on 26/7/11 at 10:28 PM Reply With Quote
Use a blowtorch on the nuts to melt out the nylon locking inserts. You would want to replace the hubnuts anyway.
wombat
posted on 27/7/11 at 06:01 AM Reply With Quote
Passenger side is left hand thread, notches in nut will confirm.
DIY Si
posted on 27/7/11 at 09:33 AM Reply With Quote
I ended up carefully cutting mine off with a hacksaw! I just couldn't get them to stay still in the vice and still have enough room to use a long bar.
Sun Tzu, The Art of War
