Author: Subject: Inner tie rod replacement help...
jossey
posted on 11/12/11 at 02:30 PM Reply With Quote
Anyone know where I can buy the inner tie rods for my mk2 steering rack. It's a quick rack and has no play but the rack ends are trashed after welding extensions up which don't fit my new tiger :-(
I've looked about but without success..... Has anyone changed the tie rods before.....
David Johnson
Chippy
posted on 11/12/11 at 02:36 PM Reply With Quote
Picture would be handy, showing the parts that are stuffed. Cheers Ray
jossey
posted on 11/12/11 at 02:43 PM Reply With Quote
That is a tie rod.
Mine has been cut and welded
David Johnson
Ben_Copeland
posted on 11/12/11 at 03:06 PM Reply With Quote
Have you tried talking to Rally Design, as they sell the mk2 quick racks...
Ben
Locost Map on Google Maps
Enter Your Details Here
mad-butcher
posted on 11/12/11 at 05:09 PM Reply With Quote
Isn't cut and shut on steering components frowned on by vosa, certainly wouldn't fancy it myself
tony
jossey
posted on 11/12/11 at 06:03 PM Reply With Quote
tony
Hence the replacement
Would be ok for track day but not for road use
David Johnson
ashg
posted on 11/12/11 at 07:45 PM Reply With Quote
tony
if its done properly i cant see the issue. a prop is welded and fly round at stupid rpm.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 12/12/11 at 04:53 PM Reply With Quote
tony
But a propshaft it isn't a slender strut in compression, and RWD Propshafts are generally seamed welded low carbon mild steel not high tensile medium carbon steel.
posted on 12/12/11 at 04:57 PM Reply With Quote
tony
Are you sure about that?
jossey
posted on 12/12/11 at 08:16 PM Reply With Quote
well unless you pull back the rubber cover you cant see its been welded which i would guess they wouldnt do.
Anyway im gonna get new inner rod ends so i will be ok as ive got proper extensions now.
ANYONE got any spare inner track rods please?
or a cheap mk2 rack i can buy?
David Johnson
