daniel mason
| posted on 8/1/12 at 09:48 AM |
Ride heights
Where exactly do you measure ride heights for setting up the kit. I have no accurate tooling at the moment but am hoping to get some set up gear
DIY Si
| posted on 8/1/12 at 10:12 AM |
It doesn't really matter as long as you use the same place each time. Having said that, most will use the bottom of the chassis rail as
it's the easiest place to measure consistently.
Sun Tzu, The Art of War
MakeEverything
| posted on 8/1/12 at 10:36 AM |
Yes, it needs to be a fixed datum. If your dampers and springs are adjustable, measure from the bottom of the wishbone mount to the floor, as long as
the floor is level and flat!
Kindest Regards,
Richard.
