daniel mason
| posted on 15/1/12 at 10:45 AM |
lightweight disc type rear bearing carriers
is there any available? the standard items are very heavy and one of mine is binding quite badly and i cant find out where?
and are they available with bearings pressed and caliper mounting brackets attatched? sierra items obviously! cheers
mark chandler
| posted on 15/1/12 at 11:01 AM |
Hello Daniel
My new bearings bound for the first 50 miles, this is not unusual and does not seem to have any long term affects.
I stuck my carrier in a lathe and shed weight this way, I believe westfield make alloy carriers as do others but really expensive.
Regards Mark
[Edited on 15/1/12 by mark chandler]
matt_gsxr
| posted on 15/1/12 at 11:37 AM |
The drum baked bearing carrier is much lighter weight, and you can use a simple adapter plate for mounting the disks with these.
I suppose this would mean changing the driveshafts to tripode on the outer end, so probably more work than you want.
rdodger
| posted on 15/1/12 at 12:17 PM |
Or you can do what I did and have the disc bearing carrier machined down to fit the Wilwood Powerlite 240mm disc handbrake kit.
snakebelly
| posted on 15/1/12 at 02:15 PM |
Or you could buy a pair of low mileage good condition disc type bearing carriers of me! U2U me if your interested mate.
snakebelly
| posted on 15/1/12 at 04:39 PM |
or at the risk of doing myself oput of a sale here is what im replacing them with, there very light!
http://www.berrisford.co.uk/product_info.php?cPath=42_51&products_id=122&osCsid=59m6q4amqoffui5h9amue3pkn4
You just need to add a caliper mounting bracket
rdodger
| posted on 15/1/12 at 05:57 PM |
I bought some of those but the Wilwood powerlite caliper bracket won't fit with them. The diameter is too large and the mounting face too thick.
snakebelly
| posted on 15/1/12 at 08:01 PM |
having my own cut to suite
