Niels
| posted on 7/4/14 at 08:18 PM |
From drum brakes to disc, a bit lost
Hi all,
As I'm rebuilding my MK indy completely I would like get a better braking system. It originally had drums at the rear but I would like to swap
them for some discs. Preferably wilwood or hi spec (any advise or experiences on these is appreciated as well)
Anyway, I'm a bit lost in the amount of possibilities and set ups. What kind of uprights do I have, which one do I need, what kind of hubs, axle
and wheel flange, etc.
I've looked at rally design as well and found these kits:
http://www.rallydesign.co.uk/product_info.php?manufacturers_id=45&products_id=12234
or
http://www.rallydesign.co.uk/product_info.php?products_id=10508
Can anyone give me some advise on the needed setup for this and if the kit in the first url is suits me and what's included in this because it
doesn't really give me a clue.
My MK indy has a 7" 3.14 diff with independent push in axles (tripod). The picture shows the uprights I have (I still need to clean them up and
repaint them ).
Thanks in advance!
raptor700
| posted on 7/4/14 at 08:39 PM |
You should have the drum bearing carrier, bolt this back on and order that wilwood kit, have your rear hubs turned down to 134mm and that's
it, make up you brake lines and new handbrake.
The brackets are in the kit to hold the caliper to the bearing carrier.
Don't forget to order pads and u will need braided lines
I am currently getting my rear hubs turned down to 134mm this is so the disc fit over the hubs as it's an smaller escort disc
You can order the discs drilled as well.
I have hi spec now and are spot on, the wilwood is a 4 piston rear caliper.
That's what I know but I may be wrong.
adithorp
| posted on 7/4/14 at 08:41 PM |
Both kits include, discs, calipers and mounting plates. The rear kit also includes h/brake cables I think from memory (it was 7years ago). Make sure
they include the adapters to go from the NPT threaded calipers to 10mm brake pipes. They don't include pads; Don't go for the Wilwood
"smart-pads" as they're crap but get Mintex 1144 instead (RD sel them). The front is a straight fit but the rears require the hub
flange reducing in diameter a fraction.
The handbrake calipers are a bit short on leverage in standard form but I made a relay lever in the tunnel that increases it and I have a very nice
brake and feel.
http://jpsc.org.uk/forum/
Niels
| posted on 7/4/14 at 09:19 PM |
What do you exactly mean by turning the hubs 134mm.
I guess this are the hubs I already have coming from the drums right?
raptor700
| posted on 7/4/14 at 09:49 PM |
The part which the wheel bolts to with the 4 studs , it's currently around 140mm in diameter u need to get it trimmed /turned down on a laithe
to 134 mm so the disc fits over, this is done so u can run 13" wheels , using the drum bearing carrier brings the caliper further in so a small
disc can be used giving space for the 4 piston caliper and the handbrake lever.
I just got some delivered today and they are in my boot ready to get turned down.
You can get rid of the drum back plate,
Bolt your bearing carrier directly to the part above in the pic and fit all the wildwood parts from rally design using your turned down hubs.
raptor700
| posted on 7/4/14 at 09:52 PM |
U can run any size wheel it just makes it easier to get 13" on as it's quite tight with the handbrake lever
Niels
| posted on 7/4/14 at 10:17 PM |
Thanks, pretty clear! So whenever I keep my 15" wheels I currently have, I'm actually good to go?
