joneh
| posted on 9/5/14 at 07:12 PM |
Sierra upright questions
Evening collective fountain of automotive knowledge.
Regarding the sierra uprights;
A) What size bolt is it that holds the disc on, looks about 41 mm to me?
B) Is the thread opposite I.e. Righty loosey lefty tighty?
C) Do I need to keep the bracket that connects the caliper to the upright, as I sheared a bolt? I plan to buy new calipers, maybe Willwards and
wondered if they would use this bit or come with there own.
Cheers!
Jon
loggyboy
| posted on 9/5/14 at 07:55 PM |
Iirc the disc is held on by the four wheel bolts and maybe a small securing screw. The large hex in the centre of the hub is just for show, its cast
in the hub.
[Edited on 9-5-14 by loggyboy]
Mistral Motorsport
Ben_Copeland
| posted on 10/5/14 at 07:02 AM |
Yes, the disc is only held on by the wheel nuts and a couple of thread washers if they are still there.
The nut would be for holding the bearing together I will imagine.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
joneh
| posted on 10/5/14 at 11:50 AM |
Ok thanks.
The disc was just held on by a locking washer on one of the studs.
I want to electrolysis dip the whole upright so need to remove the bearings. Has anyone got any tips?
adithorp
| posted on 10/5/14 at 12:54 PM |
Remove cover at the back and undo big nut. Press out the hub flange; Will be awkward due to the shape of the hub and will probably bring an inner race
with it that you'll have to pull from the flange or split to remove. Press out the bearing from the hub.
For pressing the bearing you'll probably need a hydraulic press. Refit with new bearing.
http://jpsc.org.uk/forum/
