Author: Subject: Brake fluid reservoir question
Andybarbet
posted on 29/5/14 at 08:14 PM Reply With Quote
If the brake fluid reservoir has 2 outlets (to feed my balance bar pedal box with 2 master cylinders) but the tank itself that holds the fluid is just one chamber, is this ok for IVA ?
The reservoir has the sensor in the cap & will fit nicely in my chassis if its ok to use.
Thanks in advance.
iank
posted on 29/5/14 at 09:16 PM Reply With Quote
Does it have a wall moulded between the outlets? If it's from a tin-top it will probably do it that way and be fine.
Anonymous
adithorp
posted on 29/5/14 at 09:17 PM Reply With Quote
Yes it'll be OK for IVA.
Most have an internal divider between the 2 outlets (maybe 1/3 to 1/2 the overall depth) so that if one circuit leaks there there'll still be a small reserve for the other circuit.
http://jpsc.org.uk/forum/
Daf
posted on 29/5/14 at 09:24 PM Reply With Quote
Out of interest what is the reservoir off?
Andybarbet
posted on 29/5/14 at 09:49 PM Reply With Quote
Its a focus one, nice shape kind of triangular, 2 nice lugs for mounting to chassis rails too.
Like this ebay item no 321417719881
adithorp
posted on 29/5/14 at 09:59 PM Reply With Quote
Yep, that'll be fine and will pass because it's from a tin-top... Good for type approval so good for IVA. It will have an internal division.
