Sadsy
posted on 17/11/14 at 09:33 PM |
Reverse gear sprocket
Hello Im hoping someone can help me, I have an AB performance reverse kit (few years old) but the toothed gear which sits between the diff and prop is
too small in diameter. The starter gear which engages the large tooth gear fouls on the prop bolts which isn't good. I can space out the starter
motor to miss the prop bolts but it won't engage the larger gear. I need a larger gear 10mm larger in diameter, 5mm more from the tooth if that
makes sense. I have measurements jotted down and have emailed AB but he's a busy chap no reply as yet.
Fisher fury btw
Il add pics asap
Sadsy
posted on 17/11/14 at 10:35 PM |
http://i136.photobucket.com/albums/q172/sadsy/Mobile%20Uploads/9902628B-0EE2-4F79-A20D-4C91CDD025B8.jpg
[Edited on 17/11/14 by Sadsy]
Sadsy
posted on 17/11/14 at 10:37 PM |
http://s136.photobucket.com/user/sadsy/media/Mobile%20Uploads/2014-11/700FE4CD-1882-4F36-A70A-3008B8D4C841.jpg.html
CosKev3
posted on 18/11/14 at 07:32 AM |
http://www.hpcgears.com/
IIRC the gear on my kit came from above, I bought the kit off here used.
jeffw
posted on 18/11/14 at 07:44 AM |
I suggest you speak to Andy at AB...
Sadsy
posted on 18/11/14 at 08:30 AM |
Cheers guys, I'm trying to contact ab too No reply as yet
Andy B
posted on 18/11/14 at 08:38 AM |
Hi
we have had a few email issues mainly due to a BT interconnect problem (apparently) and I definitely haven't seen your email - we have a number
of different sprockets on shelf - give me a call on 01449 736633
regards
Sadsy
posted on 18/11/14 at 07:42 PM |
Cheers Andy I know your busy with all the other things! I sent it through your website so it may be that issue. I will ring tomorrow and have a quick
chat with you. Cheers
Sadsy
posted on 20/11/14 at 08:09 PM |
All sorted..... Andy Bates "AB Performance"has sorted me out with a 150mm gear from stock, this will fix my issue.... Top service, very
quick to fix the problem and very helpful on the phone, top man
[Edited on 20/11/14 by Sadsy]
Sadsy
posted on 22/11/14 at 05:02 PM |
I received the 150mm gear today, fits perfectly I hope anyone with this issue can use this thread. Thanks AB performance
