MadMaxx
posted on 14/4/16 at 11:57 AM |
Where to buy new discs
where could I buy two front disc diam: 260 mm thk: 7 mm. They are coupled to Hispec calipers on modified Escort strut for Fury, but on their site they
are apparently not available. Below some photos to help:
My re-building diary:
http://www.llcc.it/YetAnotherForum.NET/default.aspx?g=posts&t=13448
FuryRebuild
posted on 14/4/16 at 12:19 PM |
I'm jumping in with a me-too. I could do with 280mm non vented, and either rotors for bells, or disks.
M
www.furyrebuild.co.uk
Dingz
posted on 14/4/16 at 12:58 PM |
At a casual glance judging by the webbing thickness they may be a standard disc but with the centre bore opened up.
Not much help though
went on and on.
loggyboy
posted on 14/4/16 at 12:59 PM |
Mintext brake book is quite good:
http://www.brakebook.com/bb/mintex/en_DE/expertSearch.xhtml?reset=1
but there is nothing shown for solids in 108pcd and 260 diam.
Closest i could in solids were
7mm thick, 244mm that are no longer available or 224mm
or 247s in 8mm thick
If you go to 9mm you get more options.
Mistral Motorsport
theconrodkid
posted on 14/4/16 at 01:46 PM |
http://brakeparts.co.uk/#!/
look like modified ford items,that above site gives dimensions.
who cares who wins
pass the pork pies
obfripper
posted on 14/4/16 at 07:35 PM |
Aren't they machined down e30 bmw front discs, thinned to 7mm with newly drilled hub mount holes and machined out areas where the original bmw
mount holes were?
Dave
Edit: There's some dimensions here for the bmw discs to check, you would need to get someone to machine the appropriate areas to match.
http://www.opieoils.co.uk/pv-99331-brembo-front-pair-solid-brake-discs-08306810-bmw-3-e30-set-2-discs.aspx
[Edited on 14/4/16 by obfripper]
MadMaxx
posted on 16/4/16 at 05:51 PM |
mount holes were?
Dave
Dave, your suggestions could be correct, even if there still is a dimension that doesn't match. The four slots are definitely done to remove
holes in wrong position looking the sketch I done with the dimensions of my discs:
MadMaxx
posted on 17/4/16 at 06:20 PM |
No other suggestions for a ready to fit discs from Fury owners?
[Edited on 17/4/16 by MadMaxx]
Rich J
posted on 17/4/16 at 06:57 PM |
Are the 260 x 10mm thick solids that Hi Spec supply too thick for the caliper?
Try Rally Design - they may be able to help as they sell a Cortina base Willwood kit using 265mm solid discs
[Edited on 17/4/16 by Rich J]
MadMaxx
posted on 17/4/16 at 08:12 PM |
I think so, but they updated their site and this size is not anymore on sell, so I wonder if somebody will share the alternative found to replace
them.
thefreak
posted on 18/4/16 at 03:39 PM |
I should be able to help...
There doesn't seem to be a 260x7mm off the shelf disc for starters.
The largest 7mm thick disc is a 244mm
From your sketch I'm seeing the total height of the disc is 34mm, correct?
There is a 273x10.3mm disc with total height of 33mm which could be turned down, so long as it's not too thick for the caliper.
There's also a 258x9mm with 33mm height
There's a 280x12 with 34mm height
276x10 with 35mm height
The other option is go 2 piece with aluminium bell?
