dbrank28
posted on 22/9/18 at 02:50 AM |
Axle bearing
hello new here. I've searched the forums and cant find anything on it. I have a CBR900rr going to a jack shaft then to a chain driven rear diff.
Im trying to find out what I should use for jack shaft bearings that can withstand high rpms. Thanks
jossey
posted on 22/9/18 at 08:21 AM |
Speak with ab performance they should be able to help and supply.
David Johnson
owelly
posted on 22/9/18 at 09:24 AM |
What have you got supporting the jack-shaft?
http://www.ppcmag.co.uk
dbrank28
posted on 22/9/18 at 02:36 PM |
i believe they are cassette bearings. The problem is the output on the current engine is on the right side of the car and when i switch to the cbr its
on the left. Ill have to flip the current jack shaft and cut it down more than likely. The jack shaft is tapered at the end with a bearing cap on it.
Im just not sure what the bearings will be able to handle. I have the rev limiter set to 6500 with the current engine and the CBR will be 13000 so its
double. I just dont want to be replacing these things every week.
40inches
posted on 22/9/18 at 02:53 PM |
I assume you will be using the CBR gearbox? The reduction gear between the engine and gearbox will reduce the output speed to near car engine values.
