Author: Subject: Is it enough?
nitram38
posted on 27/5/06 at 08:37 AM Reply With Quote
Is it enough?
I have been trying to get my steering to self center.
I only have 3.5 degrees of castor and I have 0.5 degree toe in on both front wheels.
I know about the toe out trick, but I would much rather the car works ok without it.
I have experimented with different tyre pressures. At 45lb nothing, but at around 25lb I get some movement.
With my wheels on full lock and at about 5-10 mph, the wheel shows signs of self centering, but they are very slow jerky movements.
Will this be enough to "show signs of self centering" that I have heard about here?
[Edited on 27/5/2006 by nitram38]
OX
posted on 27/5/06 at 09:23 AM Reply With Quote
when they test the self centering they drive round in circles at quite a pace and then let go of the steering wheel and as long as it shows signs of trying to straighten up i think you'll be ok but i suppose it depends on the test station.try that and see what happens
nitram38
posted on 27/5/06 at 09:31 AM Reply With Quote
The test station is Mitcham.
Anyone else have experience of sva here and what was the tester like on self centering?
donut
posted on 27/5/06 at 10:23 AM Reply With Quote
When i took my 1st Indy in i did nothing to aid self centering except for a bit of toe out. The tyre pressure was about 28psi or std from Halfords and i think this helps a bit. Apart from that mine was as built. I can't remember how much it self centered but it must have a bit to pass.
[Edited on 27/5/06 by donut]
nitram38
posted on 27/5/06 at 11:25 AM Reply With Quote
Cheers Donut.
My test is on 27th June.
Hopefully I will see you at Newlands (wherever that is!!!!!!!!!!)
