Author: Subject: Brake fluid flexi from res to m/cl
JohnN
posted on 4/7/06 at 10:42 PM Reply With Quote
Anybody any idea where I can get some brake fluid certified hose to go from remote reservoir to master cylinders, Mr sva didn't like the Cohline stuff I had as it wasn't all labelled up as brake fluid pipe. I can't seem to find anybody that sells such stuff
Thanks JohnN
Peter M
posted on 4/7/06 at 10:56 PM Reply With Quote
You could try these.
clicky
my previous cars
my westfield build
RichieC
I dont know of any which are labelled specifically for brake fluid in the same was as petrol hose, but if you can get some Sytec FH013 (available from many retailers - Demon Tweeks and FSE included) it is fully compliant for low pressure fuel and brake fluid.
I bought some stainless braided hose which is in fact FH013 inside, heres the spec sheet if it helps you
Rgds
Richie
[Edited on 4/7/06 by RichieC]
piddy
posted on 5/7/06 at 01:42 PM Reply With Quote
Got mine from BGC.
A very nice chap to talk to and the hose came with a spec and test sheet.
link
iank
posted on 5/7/06 at 02:08 PM Reply With Quote
What Cohline tube did you use? There are some spec sheets here:
http://www.newcoproducts.com/cohline/index.htm
If it's the 3011 Polymide tube for example there is a manufacturer sheet claiming it's brake fluid resistant.
Might be worth calling Mr SVA and checking what DIN numbers/proof he will accept.
[Edited on 5/7/06 by iank]
