Danozeman
| posted on 10/7/06 at 04:17 PM |
Speedo cable for smiths speedo.
I have a smiths classic speedo and a type 9 box..
Does anyone know what speedo cable i need?? Will a sierra one do it??
Probably in the wrong section i know.
Dan
| posted on 10/7/06 at 05:43 PM |
Smiths used different threads, if it is the small one used by Triumph Lotus a 60s Ford one defo fits eg Ford Anglia, Mk1 Cortina, Corsair.
Mk2 Cortina should also be OK
| posted on 10/7/06 at 06:10 PM |
Dan , you might find that fitting a speedo cable to a type nine in a Luego is a tight fit . If you can get one in then I think that Europa Car Spares
can make a cable to your requirements .
Alan B
| posted on 10/7/06 at 07:31 PM |
Also Speedy cables (if they still exist) are excellent..just tell them what fits on each end and how long it needs to be, and bingo.....job done.
edit:...yes they still exist.
http://www.speedycables.co.uk/
[Edited on 10/7/06 by Alan B]
Danozeman
| posted on 10/7/06 at 08:29 PM |
I was thinking right angle drive out of the box??
Dan
Danozeman
| posted on 10/7/06 at 08:38 PM |
linky,
Going by this mines an SAE thread as its an 80mm case. So what does this mean?
Dan
Deckman001
| posted on 10/7/06 at 08:46 PM |
Don't forget you might have to get the speedo re-calibrated to match your final drive ratio
Jason
Danozeman
| posted on 10/7/06 at 08:53 PM |
Im expecting that. Im not lucky enough to get it right first time.
[Edited on 10/7/06 by Danozeman]
Dan
Deckman001
| posted on 10/7/06 at 08:59 PM |
If you get the cable from the same peeps, ie speedy cables, you might be able to ask for a discount with the recalibration as well ?? It's
worth asking
I'll have to do the same if I keep the clocks I have
Jason
