Author: Subject: Will these be ok?
locoboy
posted on 18/7/06 at 09:32 PM Reply With Quote
Will these be ok?
Will these Ebay link be ok to use on the rear of my GTS panther running standard LSD (non cossie) set up
Are they the same as any other standard sierra rear callipers or do the cossie ones differ to normal ones?
Locoboy
MENZHILL
posted on 18/7/06 at 09:37 PM Reply With Quote
Hi as far as i know only difference is mtg bracket, as cossy rear discs are bigger than say xr4x4 hope this helps.
omega0684
posted on 18/7/06 at 09:41 PM Reply With Quote
you will also need the sliders for the calipers as well, i am running a cossie LSD for a 2wd cosworth, they only have a 10.1 mm solid disc on the rear, not the vented 24mm disc that is on the 4x4 cossie rear ends.
AFAIN there rear calipers of the granada, sierra, and rear 2WD cossies are all the same, so they should be fine.
hope this helps
Alex
Chippy
posted on 18/7/06 at 11:05 PM Reply With Quote
£85, bit expensive for just half the job, even if they are new. Go to the local scrappy, around £20 for a pair, and £25 to £30, IF they need overhauling. Regards Ray. Keep it Locost.
