Author: Subject: Brake fluid warning light
The Doc
posted on 6/9/06 at 07:22 PM Reply With Quote
My master cylinder and reservoir is Cortina non-servo. Works fine. However we have no fluid sensor on top. Any suggestions? My first thought was to simply find a suitable cap with a sensor but that's not proving to be as easy as I expected - different threads - sensor 'fouling' the reservoir etc.
posted on 6/9/06 at 07:41 PM Reply With Quote
Couldn't you just swap the reservoir and cap? The Sierra one is only a push fit...
The Doc
posted on 6/9/06 at 07:56 PM Reply With Quote
If the two holes line up. Is there such a thing as a universal reservoir?
The Doc
posted on 6/9/06 at 07:57 PM Reply With Quote
pajsh
posted on 6/9/06 at 09:00 PM Reply With Quote
I had to swap my Sierra servo master cylinder for an non servo escort mark 2 as the brakes were rubbish. The eccy one was horizontal and didn't have a switch in the cap whereas the Sierra was slanted and did.
Hunted around the scappie and found a sierra one that was a perfect match both in hole location and degree of angle slope.
Thus yes you will find one that will fit.
I used to be apathetic but now I just don't care.
