Author: Subject: Cosworth rear bearings compatible with 4x4?
cloudy
posted on 13/9/06 at 02:53 PM Reply With Quote
are the cosworth rear bearings compatible with the xr4x4 ones? (lobro + discs)
James
www.warnercars.com
StevieB
posted on 13/9/06 at 03:33 PM Reply With Quote
I'm not sure there's any difference between the cosworth bearings and any other car. Check with your motor factor and they'll be able to tell you (or just grunt at you, if it's anything like my local oparts place!)
mcerd1
posted on 13/9/06 at 04:11 PM Reply With Quote
or check the part No's on Burtons site https://www.burtonpower.com/default.aspx" target="_blank">https://www.burtonpower.com/default.aspx
froggy
posted on 13/9/06 at 05:14 PM Reply With Quote
same part hub carriers are the same
Gav
posted on 13/9/06 at 08:22 PM Reply With Quote
Talked to my local motor factors today about the very subject, their are 2 types of bearings for the rear or sierras, one for pushin type diffs and one for lobro, the ones for lobros are quite a bit bigger.
This is because the pushing type ones, the bearing faces are fitted against the driveshaft itself, but on lobro the end have longer splines and the drive flange ends slide over the splines and the bearing faces are fitted against this outer sleave.
cloudy
posted on 14/9/06 at 08:18 AM Reply With Quote
Thanks guys, I hoped they would be OK and it seems so
James
www.warnercars.com
