Author: Subject: Wheel Spacers
The Doc
posted on 12/11/06 at 06:43 PM Reply With Quote
Wheel Spacers
Is the SVA man cool with wheel spacers?
oliwb
posted on 12/11/06 at 06:58 PM Reply With Quote
Can't see any reason why not, as long as your wheel studs are long enough! Can I ask why you think you need them though?? Would it not be better in the long run to get wheels with the correct offset....Oli.
russbost
posted on 12/11/06 at 07:44 PM Reply With Quote
Solid spacers were certainly no prob at SVA for me, but I would agree, better to get correct offset wheels if poss.
The Doc
posted on 12/11/06 at 08:06 PM Reply With Quote
Actually my wheels are Caterham original minilites with the correct offset. It's just that I have wide arches and an escort axle. That along with the wheels being 13" makes them look a little 'puny'. With the spacers they look fine.
DavidM
posted on 12/11/06 at 08:40 PM Reply With Quote
Mine passed OK with 10mm spacers on the rear, and with longer studs to suit. They gave a bit of extra clearance between the tyre and the trailing arm bolts and made the wheels fit the arches just right.
Proportion is Everything
RazMan
posted on 12/11/06 at 09:55 PM Reply With Quote
Make sure you get the hubcentric variety or you will probably suffer from wheel wobble.
Raz
