Author: Subject: Brake caliper position - best practice?
andyd
posted on 13/11/06 at 10:19 AM Reply With Quote
Guys,
Can I have some opinions on where the best position for the brake caliper is please?
Should they fitted in front or behind the stub axle?
What kind of angle (if any) is best or should they be kept parallel to the ground?
I'm designing my own uprights and will need to draw up the attachment of the calipers soon. My gut feel is that it doesn't really matter where they are mounted. Whilst travelling to a meeting last week (as a passenger) I was noting that most of the cars on the roads differ, some in front, some in rear and at various angles around the disc. From this I'm guessing that mainstream manufacturers situate their calipers where they fit best for the individual car.
Anyone got any info to clarify the rights or wrongs of this?
RazMan
posted on 13/11/06 at 10:37 AM Reply With Quote
It will probably depend on your own setup - just make it the most convenient position for routing your brake lines and handbrake cable.
Raz
iank
posted on 13/11/06 at 11:16 AM Reply With Quote
It's most convenient if you don't need to remove the caliper to bleed the brakes, therefore generally in the same position as the donor so your nipples are at the higest point.
andyd
posted on 13/11/06 at 12:33 PM Reply With Quote
Well I'm primarily talking about the front brakes so no handbrake but that's pretty much what I was thinking.
I'm building pretty much from scratch so no donor for those parts. I'll be using Wilwood calipers which have nipples on top and bottom.
Bob C
posted on 13/11/06 at 01:12 PM Reply With Quote
note that calipers behind axle means the braking force is taking some weight off the wheel bearings.
for what it's worth.
andyd
posted on 13/11/06 at 01:30 PM Reply With Quote
That's the kind of consideration to be erm... considered
Thanks Bob.
