les
posted on 9/1/07 at 08:57 PM |
wobbly steering column!!
Hi chaps,
I seem to have steering problems!
after fitting the steering column (sierra column in a tiger avon), with all tightened up, the top of the column describes a circle when you turn the
column- looks like the column must be bent
anyone had any similar probs?
les
stevec
| posted on 9/1/07 at 09:03 PM |
Have you got the lower bush in?
Steve.
Avoneer
| posted on 9/1/07 at 10:04 PM |
I found that a few Avons have the lower tube (that holds the plastic bush) very poorly aligned and everyone I know had to cut it off and re-position
it.
Symptons point to a bent column....
Pat...
| posted on 9/1/07 at 10:14 PM |
Had the same problem when the lower bush came out.........
bimbleuk
| posted on 10/1/07 at 10:18 AM |
Kinda related to wobbly Sierra columns on mine the triangular bush at the upper end of the column has worn. So the sliding inner tringular section can
turn a few degrees before the slack is taken up. Might be worth checking.
macnab
| posted on 10/1/07 at 10:40 AM |
jump on it that'll get it straightened
ayoungman
| posted on 10/1/07 at 11:41 AM |
All part of the Avon building challenge.
"just like that !"
