Author: Subject: Clutch Actuator
posted on 22/3/07 at 09:07 PM Reply With Quote
Clutch Actuator
Any one know if the hydraulic clutch actuator off a Mondeo will fit in the standard type 9 bellhousing?
Wondering if its worth the hassle
posted on 23/3/07 at 12:33 PM Reply With Quote
A few people have fitted them, but you need to turn up an adapter in order to mount the assembly to the front of the type 9 and ensure that it is absolutely co-axial to the input shaft.
You can buy a co-axial release bearing and mounting spacer for a Type 9 from e.g. Burtons, but they aren't overly cheap.
posted on 23/3/07 at 05:29 PM Reply With Quote
Better to use the SAAB 900 cylinder -- better quality and easier to mount.
907
posted on 24/3/07 at 08:22 AM Reply With Quote
I used the Mundano unit in my Getrag box.
I had to machine a flat area on the inside back face of the bell housing to mount it onto.
Paul G
