sgraber
posted on 18/10/01 at 02:58 AM |
Need donor source for front uprights (USA)
Still in the research stages at this point. Looking for a suitable donor for front uprights/spindles/hubs that will work with a front wheel drive
offset wheel. I will be doing a standard locost style frame but with a front wheel drivetrain in mid-engine configuration. I suppose I could use a
regular pinto/mustangII/Chevy S-10 upright with a spacer, but that is so uncool...
Any ideas?
Thanks, Steve G
Alan B
posted on 18/10/01 at 03:18 AM |
Steve,
Keep watching my site. I'll soon have my front end built using the MR2 (ex strut)uprights with adapter and spec racer upper ball joint. Maybe not
what you want but suits the FWD offsets.
Alan B
sgraber
posted on 18/10/01 at 06:03 PM |
Hi Alan!
ooooh ooooh, what ball-joint are you ending up with? Can you give me a part number? I have been meaning to tell you that I really like your solution
for the front suspension. I've been trying to come up with innovative ways of lowering the cg with pullrods and bell cranks and placing the shocks
horizontaly at the base of the frame and it just gets so damn complicated. I'm wondering if you will want to share your drawings in a detailed
fashion at some point... ahem... Since they are so darn cool and all...
Steve G
Alan B
posted on 19/10/01 at 02:22 PM |
Steve,
Yeah, no problem sharing stuff!
Let me see if it works first The ball joint part number is MOOG K3082 or TRW 10229 or equivalent. I got one as a sample for about $17 but I have
been quoted $15 (but they weren't in stock)This is the one that is shown in my "how the spec racers do it" picture on my site. The adapter is
really simple and could easily "adapt" to other similar uprights.
Alan B
7spanner
| posted on 19/10/01 at 09:53 PM |
Am working with GTS donor and was wondering the same on the uprights.
sgraber
posted on 21/10/01 at 04:15 PM |
quote: Am working with GTS donor and was wondering the same on the uprights.
Can you give more info as to your Donor? That's a Corolla GTS? What year?
86barettaguy
| posted on 2/7/08 at 05:05 PM |
wow, this is an old thread, but I had a question which is sort of on-topic here, so...
Did anyone try using Pontiac Fiero uprights and hubs for a seven-ish car?
