Author: Subject: amount of steering turns
bracey
posted on 18/4/08 at 05:49 PM Reply With Quote
what is prefered amount of turns lock to lock ,
got standard turns on mine 2.9 ?
would going quicker make a good difference ie 2.4?
cheers
richard
posted on 18/4/08 at 06:03 PM Reply With Quote
faster the better imho, when the back end goes you need to be able to point the wheels fast.
posted on 18/4/08 at 06:44 PM Reply With Quote
Yes yes yes
RazMan
posted on 18/4/08 at 11:20 PM Reply With Quote
I found a 2.4 was a little too fast for motorway cruising and the 2.9 was perfect, especially with a small steering wheel. Ardent track day nuts will want 2 turns or even less
Raz
NS Dev
posted on 19/4/08 at 10:24 AM Reply With Quote
Mine is fine as a pure road use car with 2.4 turn rack.
posted on 19/4/08 at 05:55 PM Reply With Quote
I started with the standard 3.5 turn rack, changed to the 2.4 turn one. After a while I thought it was a bit too 'brisk' so I changed back - and hated it! The 2.4 one is now a permanent fixture.
It's a bit heavy at parking speeds, but really easy at driving speeds.
I wouldn't go any slower now...
bimbleuk
posted on 20/4/08 at 05:23 AM Reply With Quote
Similar experience here I was using the car regularly on track with a 2.4 rack. Now I'm using it a lot more on the road I've gone to a 2.9 rack and its a good compromise. Maybe a little slow sometimes to catch the car on track so you can end up wagging the tail a bit more!
