Author: Subject: shocks
Matthew
posted on 11/12/03 at 12:58 PM Reply With Quote
shocks
What spring rates would you recommend for my MK with 2.0l SRI 8v engine in and what make shoul I buy I have looked at MK's and a set of gaz shocks for £250 all in.
Ben_Copeland
posted on 11/12/03 at 01:02 PM Reply With Quote
The ones supplied by GTS are good. Darren @ GTS will tell you what rates you need.
This has been gone over before many times. Do a search
Ben
Locost Map on Google Maps
Enter Your Details Here
mangogroove
posted on 11/12/03 at 03:01 PM Reply With Quote
It's the offer in this months Which Kit mag.
"Attention Locost Builders"
4x1.9 Gaz adj coil over dampers plus 4x1.9 quality powder coated springs, inc carriage and VAT.
I got them for 250 all in....they are fab
ned
posted on 12/12/03 at 09:48 AM Reply With Quote
I'm using the same engine and have 350;b front and 190lb rear. the car is not finished so this is untested. my shocks were from a 2ltr zetec car so i'm guessing the weight will be similar.
Ned.
beware, I've got yellow skin
stephen_gusterson
posted on 12/12/03 at 10:13 AM Reply With Quote
thats practically identical to my rates used on a big iron ford v6 - do you have your shocks at a shallow angle ned? the more they lay down, the more leverage and the less the effective rate.......
woulda thought your vauxhall was lighter....
atb
steve
or - could be my front is too soft - but feels and rebounds right (albiet on the drive!)
ned
posted on 12/12/03 at 10:42 AM Reply With Quote
Steve,
Shocks not mounted yet, so angle yet to be determined. These are as i said from a westfield that was running a 2ltr zetec. I'll see when it goes together....
Ned.
posted on 12/12/03 at 02:04 PM Reply With Quote
FWIW, my shocks feels very hard indeed, barely moves when i jump on the front end. Time will tell though, id rather too hard then too soft!
