Miks15
| posted on 1/9/08 at 10:59 AM |
crush tubes
My front suspension crush tubes have an ID of 13mm, but im using M12 bolts. This obviosuly give alot of play around the bolt. Should i get different
bolts? Or can i swap the crush tubes over to get the right ID?
Secondly what ID should it be for an M12 bolt? is it 12.5?
Mikkel
| posted on 1/9/08 at 11:14 AM |
Sure they are 13mm and not 1/2"? May be worth double checking, mine are all imperial although 7/16"
indykid
| posted on 1/9/08 at 11:18 AM |
sounds like they're 1/2", 12.7mm in metric
are the holes in your brackets 12mm? are they welded onto the chassis yet?
tom
James
| posted on 1/9/08 at 11:56 AM |
I'm sure you know this, but remember the crush tube doesn't rotate around the bolt.
The crush tube is stationary and the bush rotates around the crush tube.
HTH,
James
- Muhammad Ali
Miks15
| posted on 1/9/08 at 12:21 PM |
ahh right mabye they are 1/2", all my brackets are for M12 but they can easily be drilled out as not yet welded on. What are the tolerances on
it? can i drill the hole out to 13mm and it be ok?
D Beddows
| posted on 1/9/08 at 02:42 PM |
Sorry, have to say this....... why not do it properly for heavens sake and make everything either 1/2" or 12mm? Surely it's preferable to
bodging together one of the most important aspects of the car? Find somewhere else to save money if you have to, this really isn't the place to
be doing it!
Miks15
| posted on 1/9/08 at 02:51 PM |
this is the one place i have put money in...
Bought the front wishbones complete wth bushes etc... and then bought the brackets from a different supplier....
I am just wondering what the best plan of action would be? get new crush tubes to fit my bolts? or to get new bolts to fit the crush tubes and re
drill the brackets?
D Beddows
| posted on 1/9/08 at 02:58 PM |
Depends - if you have the kit to accurately enlarge the holes in the brackets I'd do that (a drillbit in a black & decker isn't
really the right kit btw ) otherwise I'd get new crush tubes and sell the ones you've got. If you didn't buy stainless crush
tubes this may be a good opportunity to get some .........
[Edited on 1/9/08 by D Beddows]
RoadkillUK
| posted on 1/9/08 at 03:38 PM |
I'm just refurbing my rear axle on the Locost and my shocks are from GTS (Nitrons I believe). All my suspension bolts are M12 other than the
suspension bolts which are 1/2".
Just to let you know, you're not on your own
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
