Author: Subject: Original locost steering
designer
posted on 1/10/08 at 07:48 AM Reply With Quote
Does the Escort steering rack fit unaltered in the Champion Locost?
It seems wrong to me!
Mr Whippy
posted on 1/10/08 at 07:54 AM Reply With Quote
yes and it does suffer a bit of bump steer apparently
Lars
posted on 1/10/08 at 07:59 AM Reply With Quote
fits well in mine
procomp
posted on 1/10/08 at 08:31 AM Reply With Quote
Hi
Yep it fits without modification. And dependent upon position and accuracy it can have as little as 16 tho of bumpsteer over 3 inch of suspension travel.
Cheers matt
Ninehigh
posted on 1/10/08 at 08:52 PM Reply With Quote
I have never heard of bumpsteer, do I want it cos it sounds like I don't?
mistergrumpy
posted on 1/10/08 at 09:11 PM Reply With Quote
Very basically put and in laymans terms. When the suspension on one side droops (camber of the road, potholes, whatever) it will drag the steering rack with it and therefore the other wheel and the car will tend to pull to that side.
It is present in some production models to a degree and unless your car is way out, you'll most likely not notice or else just tolerate it. Not to say you shouldn't try to eliminate it as much as during the build.
If you do a search you'll find loads on it.
Ninehigh
posted on 3/10/08 at 02:47 PM Reply With Quote
I get that in my mondeo! Where would I be able to find information about it, cos I got 2 cars to reduce it in!
