Echidna
| posted on 9/10/08 at 05:29 PM |
Sierra rear disc brakes
I am currently in the process of brake calculation/design and i have found a good deal for stock Sierra rear disc brakes. Prior buying the kit, i need
to know some fundamental info about the stock Sierra rear brakes.
Disc diameter
Caliper piston diameter
Fixed or floating caliper?
Any info on weights would be desirable too.
Thanks in advance for any help!
[Edited on 9/10/08 by Echidna]
Paul TigerB6
| posted on 9/10/08 at 06:00 PM |
rear disks are 253x10mm
piston diameter is 42.8mm
Floating caliper (single piston)
the above is for a 85 - 88 XR4x4.
Information sourced from here
Hope that helps anyway
[Edited on 9/10/08 by Paul TigerB6]
Echidna
| posted on 9/10/08 at 06:12 PM |
tomblyth
| posted on 9/10/08 at 07:30 PM |
there are various conitations see brakeworld catalogue
http://www.brakeworld.co.uk/link
Echidna
| posted on 9/10/08 at 07:35 PM |
Fantastic resource! Thanks a lot!
Mal
| posted on 9/10/08 at 07:38 PM |
It may help to know that Sierra rear solid discs are the same as Focus rears.
Also Compbrake sell new VW Golf style rear calipers in aluminium for about £60 each.
| posted on 10/10/08 at 08:55 PM |
Look at MGTF rear calipers 40mm piston dia -- a lot bigger piston area than the Sierra which istr is 33mm dia.
Echidna
| posted on 11/10/08 at 04:57 AM |
Sierra's rear calipers have a piston diameter of 42.8mm, not 33mm, right?
