Author: Subject: Threads, washers and reaming uprights
panichat
posted on 29/10/08 at 08:52 PM Reply With Quote
Cortina uprights.
My upper bj does not protrude enough to provide visible threads so I have some questions:
Has anyone tried grinding out the tapered hole using valve paste and a tool made from an old transit bj?
Do you have to have a washer on the upper bj?
Is this a common problem or am I wierd (a search reveals lots of issues with maxi lower bjs but the upper ones don't seem to be mentioned) ?
For suspension and shock bolts do you use a spring washer or a flat washer?
Thanks everyone
Dave
maartenromijn
posted on 29/10/08 at 09:03 PM Reply With Quote
I have cortina uprights, and it's a perfect fit with the Transit TRE's. Conus width 16mm if I remember correctly.
I use flat washers and Nyloc nuts on the suspension, so no need for spring washers.
BLOG: http://thunderroad-super7.blogspot.com/
posted on 30/10/08 at 07:18 PM Reply With Quote
Probably the ball joint at fault, some are a bit short . ISTR someone wrecked an upright trying to adapt it to fit the ball joint. Better to get another joint.
