<<  1    2  >>
Author: Subject: Hydraulic hnadbrake
posted on 29/5/04 at 11:09 PM Reply With Quote
Some rally enthusiasts I know use a separate master cylinder that is plumbed in line with the rear brake pipes. When the (hydraulic) handbrake is off, pressure from the main foot brake is transfered through the handbrake master cylinder. With the handbrake on, the second master cylinder effectively shuts off the main brake lines, and applies pressure to the rear brake slaves.
The advanatge of this is that the mechanical system (e.g. cable) can remain in place to satisfy the legal requirement of two independant braking systems (although in practice the cable seems to be adjusted so loose it doesn't really do much).
jollygreengiant
posted on 30/5/04 at 09:21 AM Reply With Quote
Originally posted by leto
We have just started to investigate this as it became clear that hydraulic handbrakes can be street legal (in Sweden) The handbrake can be made to work on the same pipe and cylinders as the foot brake by some sort of valve. Exactly how is still a mystery to us but we are working to solve it.
Not much help.
If I remember correctly, the way that I/we used to do it was to splice a remote (no integeral fluid reservoir) clutch slave cylinder( it allows almost un-restricted fluid flow when off) into the front to rear brake line at the appropriate distance from the hand brake lever and the connect a rod between the two. Job Done.
Enjoy
Miller
posted on 2/6/04 at 06:49 AM Reply With Quote
Ok what you are looking for is something called a turning break. Dune buggies have been using these for years. They allow you to lock up the lefr rear wheel or the right rear wheel seperatly via a hydraulic levar. Here are some different kinds.
http://www.cbperformance.com/catalog.asp?ProductID=932
http://www.cbperformance.com/catalog.asp?ProductID=1189
I plan to buy a hydraulic handbrake and a line lock for an e-brake.
<<  1    2  >>
