Poll: Equal or different Wishbones? [View Results]
Equal Length -
Short top, Long Bottom -
MacPherson strut suspension -
<<  1    2  >>
Author: Subject: Equal or different Wishbones?
TallGuySmallBike
posted on 10/2/14 at 08:42 PM Reply With Quote
Damn it. i just found out what it was
You got me first.
Found this
[Edited on 10/2/14 by TallGuySmallBike]
Sam_68
posted on 10/2/14 at 08:56 PM Reply With Quote
Originally posted by TallGuySmallBike
Also as for the king pin.. I was talking of this off set. Is this some kind of different angle needed?
Yes, you need caster as well... about 6 degrees worth of it, as a ballpark figure.
TallGuySmallBike
posted on 10/2/14 at 09:02 PM Reply With Quote
Right well, Going off this i can try and work somthing out. Back soon!
TallGuySmallBike
posted on 10/2/14 at 11:27 PM Reply With Quote
300 mm Lower wish bone.
240 - 250 mm Top Wishbone
300mm between the centres of pivots that attach the wishbones to the frame.
Thus giving a 9 degree King pin tilt thingymebob.
PhillipM
posted on 12/2/14 at 02:03 AM Reply With Quote
What's the roll centres/instant centres like with that setting? They seem pretty short wishbones is all....
You'll want to be careful with the plunge on the driveshafts too, shouldn't be quite as bad with a double wishbone generally but it's worth checking just in case.
P.S. XUD's suck balls - Ripp
[Edited on 12/2/14 by PhillipM]
TallGuySmallBike
posted on 12/2/14 at 06:54 PM Reply With Quote
P.S. XUD's Are so amazing.. They are just the best - Ripp
This is a rough calculation.. Still finding my feet here.
https://www.flickr.com/photos/116905236@N06/12484459283/
<<  1    2  >>
