<<  1    2  >>
New Topic New Reply
Author: Subject: tube cutting problems
Mark Allanson
posted on 13/11/04 at 10:48 PM Reply With Quote
Originally posted by gazza285
That's 15 years of pipe welding experience up the spout then.
This isn't pipe welding, its chassis welding. I was a pro pipe welder, and not normally one to quote credentials, but I have ASME IX in 1-6G and BS4872 in just about every other form of welding except MIG braze, but I am waiting the results on a recent test (confident).
The difference is that any distortion in pipe will be on the last weld in the pipe, I used to use blade wedges and chalk (yes, Rorty chalk! to give 1" warning of a wedge, you cannot see them coming up when using EW13's and a very tight arc on low hydrogen)
Thin wall tube needs to be touching, at the very least, and usually cut long and beaten into place to make allowances for the contraction, you need to be in control of the distortion and use it to do what you want rather than be a victim to it. You are going to loose about 25% of the fillet width as the metal cools - so make allowances
cassidym
posted on 13/11/04 at 10:58 PM Reply With Quote
Mark, for a newbie's education - how do you make allowance for the contraction?
Currently distortion is my main enemy and I still have'nt got that intuitive understanding of distortion and how to manage it properly.
Mark Allanson
posted on 13/11/04 at 11:27 PM Reply With Quote
After I had fully welded my chassis, I had 3mm lift on the right and 4mm on the left, I cut the (quick look in book!) TR tubes 2 and 3mm too long and wedged them in after raising the chassis on spare bits of rhs/erw. This dipped the chassis by 1mm on both sides. After welding it was true on both sides. If the chassis had drooped, I would have cut them short and let the distortion draw the chassis up.
Rorty
posted on 14/11/04 at 01:53 AM Reply With Quote
Originally posted by Mark Allanson
... I used to use blade wedges and chalk (yes, Rorty chalk! ...)
Sorry Chalky!
Cheers, Rorty.
cassidym
posted on 14/11/04 at 11:03 AM Reply With Quote
My accuracy greatly improved when I started using a scribe.
A problem still is when I want to draw a line across all faces of the tube. The round edges of the corners throws me off by a .05 to 1mm which I find unacceptable.
I've tried diff. techniques to extend the line but it's still a 50/50 type of affair.
Thanx guys.
pintoman
posted on 14/11/04 at 04:09 PM Reply With Quote
cut a peice of 1" angle iron
locate on one scribe mark and mark off other edge
cassidym
posted on 14/11/04 at 04:32 PM Reply With Quote
Why do I suddenly feel so stupid! zaz
Very, very obvious solution - thanx pintoman. vc
cassidym
posted on 14/11/04 at 05:45 PM Reply With Quote
Sorry bout the extra words at the end of each sentence.
No it's not a foreign language - it was my 1 year old son who helped me with my reply, little bugger.
posted on 14/11/04 at 06:19 PM Reply With Quote
I know what you mean
I had 3 year old grandson helping me modify an airbox the other day. His solution to what to cut it with, some scissors .
posted on 14/11/04 at 06:28 PM Reply With Quote
i didnt even notice them. hgd
<<  1    2  >>
New Topic New Reply
