gremlin1234
| posted on 13/2/17 at 08:53 PM |
quote: Originally posted by Dingz
https://www.locostbuilders.co.uk/photos.php?action=showphoto&
Will this picture work?
Still Vauxhall, Victor FE
Could be Record/Commadore as previously mentioned
Floor pans were the same
[Edited on 13/2/17 by Dingz]
the picture works as a link
but easier like this
  Description ball joint
do you have the dimensions on the splines too ?
Dingz
| posted on 13/2/17 at 09:13 PM |
Haven't got the dimensions but it looks a bit different to the original picture which the poster said wasn't the right one anyway.
The CF van was going to be marketed as the 'Blitz' in Germany !
went on and on.
ashg
| posted on 13/2/17 at 11:39 PM |
looks similar to a ford ranger ball joint to me. do you have a picture of the upright or the suspension arm?
[Edited on 13/2/2017 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
alfas
| posted on 19/2/17 at 10:42 PM |
this week the bedford items arrived
spline diameter ok
height ok
thread ok
taper too big (~17mm)
today i visited my mate....but havent seen your posting until now, otherwise i could have taken a pic
we tried also all different kind of opel´s and we always come back to the same problem, as with the vauxhall items....spline too small
[Edited on 19/2/17 by alfas]
alfas
| posted on 20/2/17 at 10:00 AM |
those are pressed from the top and secured on the bottom by a seeger.
the ones i search are pressed from bottom and secrued on top by a seeger (as seen in my opening post)
here a pic of the original one:
[Edited on 20/2/17 by alfas]
gremlin1234
| posted on 20/2/17 at 11:13 AM |
if the taper is too big, can you ream out the hole it has to go into
like the second post on this page
http://mx5-haynes-roadster.blogspot.co.uk/2011_10_01_archive.html
edit:actually third post.
[Edited on 20/2/17 by gremlin1234]
alfas
| posted on 20/2/17 at 12:02 PM |
enlarging the taper could be done in a future stage, even we dont prefer it, as there is not so much material left.
alfas
| posted on 6/3/17 at 08:51 PM |
meanwhile we fitted the old ones (there was no mechanical wear)....we cleaned them, new grease, new dust-caps...and maybe time will bring the correct
ones.
changing the taper on the car is not a solution for us.
