<<  1    2  >>
Author: Subject: Tightening up a Type 9
Benzo
posted on 11/8/18 at 09:08 AM Reply With Quote
Originally posted by mikeb
Any ideas what this kit does
https://www.rallydesign.co.uk/product_info.php?products_id=2007
just looks like a shorter lever that fits over the top if you cut down the original, RD list it a a quick shift?
M
So after all that i've gone and bought a quaife clubman box complete with quaife quick shifter / stick
I still however think that the the stick is too far away & the bend on the stick doesn't give as nice an input as a straight stick into the box, so has anyone actually tried / used one of the rally design turret extensions? are they a good job?
posted on 11/8/18 at 11:35 AM Reply With Quote
Use the search facility on here , DIY remote extensions and quick shifts have been covered several times. Made mine as have others , mine cost the total of £0.92 for the remote and quickshift
Benzo
posted on 11/8/18 at 11:38 AM Reply With Quote
Brilliant I will have a look! Cheers!
posted on 11/8/18 at 11:45 AM Reply With Quote
Pretty sure it was posted by David Jenkins. Mine extended the gear lever back by about 5 inches , the gear change is smooth and precise with very little movement.
posted on 11/8/18 at 02:26 PM Reply With Quote
'twas I wot did it!
Info here: linky
The whole of my site can be found by pressing the WWW button below.
You'll have a bit of working out to do, as I never got around to drawing up the dimensions. Not too difficult to do - I managed it! You will need access to a lathe though. The hardest part is to get the reversing cam aligned correctly before welding - if you're uncertain about welding this properly, there's no reason why the whole thing couldn't be brazed (if done properly).
<<  1    2  >>
