Author: Subject: Ball Joints
posted on 5/11/08 at 12:52 PM Reply With Quote
Ball Joints
The MK Indy uses the Transit top balljoint on the front suspension. Is there an alternative ball-joint with a greater range of movement that can be used and if so, can it be used with the original mushroom adapter, or will it require a modified mushroom or top wishbone?
Phil
