Author: Subject: Sierra master cylinder
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
Building: a sense of satisfaction now things seem to work ok
posted on 12/11/08 at 09:08 PM Reply With Quote
Hi all,
I have been trying to fit the sierra master cylinder to the Robin hood pedal box assembly and as you might expect the holes in the RH assembly dont match the sierra fixings holes.
Does anyone know what the spec the standard sierra master cylinder and if there are any other master cylinders i can use in its place? For info the fixings in the pedal box are in the 6 and 12 o'clock positions and not rotated as the sierra one is.
Thanks in advance for any advice.
P.s. the car will need to be SVA ok so I need to keep the low fluid sensor etc.
Chris
Mark Allanson
posted on 12/11/08 at 09:38 PM Reply With Quote
There are 4 variants of the sierra MC, you may have the wrong one
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 13/11/08 at 08:25 PM Reply With Quote
Do any of these 4 different master cylinders have the fixing lugs at the 6 and 12 o'clock positions or are they all rotated by 30 odd degrees??
Chris
posted on 14/11/08 at 01:38 PM Reply With Quote
there are at least 2 variants. mine my havethe lugs at 12/6 o'clock bout I won;t be able to check un til Wed next week. u2u me then if you want me to check.
