Pdlewis
| posted on 14/11/08 at 09:15 AM |
sierra rear brakes
Morning,
bit of a noddy question how to i get the pistons to retract in sierra rear brakes. they arnt on the car so nipple fully open and i can only get it to
retract enough to fit the pads and not the disc
Build Photo Album
Updated 05/02/2009
Davey D
| posted on 14/11/08 at 09:18 AM |
you need to screw the piston back in.. the spanner you get with an angry grinder works great
Mr Whippy
| posted on 14/11/08 at 09:24 AM |
as above, should turn quite easily
Vindi_andy
| posted on 14/11/08 at 10:58 AM |
You need to push and turn As said above spanner for angry grinder works great.
Just remember dont apply the handbrake until you have bled the brakes.
adithorp
| posted on 14/11/08 at 01:15 PM |
As above ^^^ DON'T operate the handbrake untill you've pumped the pads out with the footbrake.
adrian
http://jpsc.org.uk/forum/
piddy
| posted on 14/11/08 at 06:43 PM |
As above turn clockwise with pressure to
Retract anti clockwise to bring back out.
The instruction I have with the ones I've just brought say turn in fully clockwise and then half a turn back, fit and then check clearance (0.25
to 1mm) adjust accordantly and then bleed brakes then fit handbrake.
Neil P
| posted on 14/11/08 at 07:06 PM |
What happens if you do use the handbrake before bleeding the brakes?
Neil
Pdlewis
| posted on 14/11/08 at 07:14 PM |
Worked a treat cheers guys
Build Photo Album
Updated 05/02/2009
adithorp
| posted on 14/11/08 at 08:14 PM |
Neil
The adjuster mechanism can go tits up.
adrian
