philhoward
posted on 17/11/08 at 04:02 PM |
Cycle wing brackets
I am thinking of changing my cycle wings to carbon fibre ones from Carbonmods. Where is the best place to get new brackets from?
bbwales
posted on 17/11/08 at 04:04 PM |
Which hubs are you using?
Bob
philhoward
posted on 17/11/08 at 04:09 PM |
I think that they are Sierra ones. They are fitted to a Tiger Supercat
bbwales
posted on 17/11/08 at 04:18 PM |
If they are Sierra ones then I like the design and manufacture of Mac#1, if you decide to use them remember to tell them which calipers you are
using.
Regards
Bob
[Edited on 17/11/08 by bbwales]
bob tatt
posted on 17/11/08 at 04:30 PM |
why do you need to change the brackets suerly the carbon mods ones will fit onto them
philhoward
posted on 17/11/08 at 04:49 PM |
My existing brackets are moulded into the cycle wings and would be a pig to get off. Also they are bent and rusty.
Does anyone have a picture and price of the Mac#1 ones as I cannot find them on their website.
bbwales
posted on 17/11/08 at 05:09 PM |
I haven't mastered the art of attaching photos here, if you u2u me your email address I will send you a couple of pics.
Bob
ReMan
posted on 17/11/08 at 10:53 PM |
Hows that then.
Def my favorites after I junked the MK ones at first attempt!
[Edited on 17/11/08 by ReMan]
procomp
posted on 18/11/08 at 08:52 AM |
Hi
Why the hell are all these manufacturers supplying the equivalent of the Forth bridge just to hold a cycle wing on.
Why not just get a bit of 50 x50x5 alloy right angle shape to suit. Then weld it to the top of the mushroom with the other flange vertical meaning you
could mount some 25x5 steel strip up and over the wheel / tyre.
I have been doing it this way for 10 years without any problems so certainly works with the abuse the race cars get.
Cheers Matt
Edit Have added a very quick sketch in my archive if that description makes no sense.
[Edited on 18/11/08 by procomp]
:{THC}:YosamiteSam
posted on 18/11/08 at 03:30 PM |
i had something simialr on my dax after the 3rd stay snapped - bollox to that i said - i made my own - it needs to be heavy enough to not wobble which
induces fatigue - flat bar (min 5mm) with a GENTLE bend works best - sharp bends will be the point of failure
the wider the bar the more area of glue contact as well - worked wonders and even stayed on after double barrell rolling down an embankment landing on
the them - sikaflex 221 - clean the undersides with a 'chimeny brush' type wire brush in a drill - degrease - then plaster the adhesive on
- apply the wing - gaffer tape in position - smooth excess around stay edges - leave for at least 24 hrs - will last for ages..
