Author: Subject: brakes...
A1
posted on 26/11/08 at 09:36 PM Reply With Quote
brakes...
just put the fluid in the system and bled each caliper individually, but the brakes are really spongey...ive got wilwoods on the front and sierras on the rear...
bigrich
posted on 26/11/08 at 09:45 PM Reply With Quote
if the bleed nipples are at the bottom on the rears you need to remove the calipers place the nipples at the top and re bleed then refit
austin man
sierra what disc or drum ?
if its disk I believe you have to lower the top of the calliper as air remains trapped within the calliper a part of the calliper (or was it raise the bottom?) we had this problem on an MK Indy.
omega0684
posted on 26/11/08 at 09:46 PM Reply With Quote
might seem obvious but have you checked all the joins for leaks, get wifey involved to pump the brake! extra eyes etc
Howlor
posted on 26/11/08 at 09:51 PM Reply With Quote
Virtually guaranteed to be air in the system somewhere. An Eezi bleed system is really worth it.
I had the same problems but after a lot of bleedin bleeding I got them right!
A1
posted on 26/11/08 at 09:58 PM Reply With Quote
cheers, its sierra discs at the rear, ill try removing the callipers and re bleeding tomorrow!
fingers crossed!!
Chippy
posted on 26/11/08 at 11:15 PM Reply With Quote
Just make sure that you put something in between the brake pads before you bleed them, (on mine I can just get them to sit on the disc's up the other way), otherwise the pistons will come out, destroying all your good work, :-( Cheers Ray
Paul (Notts)
posted on 27/11/08 at 07:48 AM Reply With Quote
as above!!!
speedyxjs
posted on 27/11/08 at 08:04 AM Reply With Quote
As said ezi bleed system is defo worth it and cheap. About £15 iirc
Antnicuk
posted on 27/11/08 at 08:34 PM Reply With Quote
i have the same set up to your, it took me ages to bleed the brakes fully. I did it 3 or 4 times iirc. Do you have seperate M/C's?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
