Author: Subject: atlas axle panic! HELP!
blakep82
posted on 1/12/08 at 08:04 PM Reply With Quote
is the axle casing from, say, a 2.0 capri any different from a 2.8 capri?
________________________
big_wasa
posted on 1/12/08 at 08:31 PM Reply With Quote
Not that I am aware, the crown wheel and pinion are interchangable ect.
Antnicuk
i cant be certain but i think they are the same, i have a 2.8 lsd and have been told i could put the higher ratio cw+p from a 2 litre.
So a conclusive answer would be nice.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
blakep82
posted on 1/12/08 at 08:34 PM Reply With Quote
i hope you guys are right
been asking SHP about their half shafts for my truck. got this in an email
"These halfshafts are no longer a SHP held product as we only use G4 type in the current Pickup Trucks which in theory prove to be indestructable the only problem you have with these shafts is the side gears as they will need to be changed if you use a 2.8 Capri limited slip drive unit."
just got me worried why they were so specific about the 2.8 capri diff! and i thought the capri LSD would be the one that didn't need side gears replaced.
since my axle has cost the best part of £1000, and been built out of a 2.0 axle...
maybe its just the ratio they use? think mines 3.44
[Edited on 1/12/08 by blakep82]
omega 24 v6
posted on 1/12/08 at 10:07 PM Reply With Quote
IIRC the atlas group 4 half shafts use a different no of splines (see burtons site) this is why the side gears need to be changed. AFAIK the axle range is the same across the capri range with the exception of the lsd unit in some of the 2.8's.
Yep just checked a group 1 shaft has 16 teeth and a group 4 has 18 teeth.
[Edited on 1/12/08 by omega 24 v6]
blakep82
posted on 1/12/08 at 10:15 PM Reply With Quote
yeah, i knoew the different number of teeth, it just worried me where they said i'd need to change the side gears in the 2.8 capri diff, and not just the diff in general.
I was just worried in cas there wa something different about the casing in the 2.8 compared to the others that meant i'd just wasted a good few hundred quid retubing an axle from a 2.0, like the diff housing being different, and the diff a bit different, meaning the 18 tooth side gears wouldn't find my diff, and any of the 18 tooth side gears ONLY fit 2.8 diffs, which wouldn't fit my axle etc etc.
just sudden'y got me in a panic
