New Topic New Reply
Author: Subject: Sierra steering column mounting
dubstar_04
posted on 6/12/08 at 05:26 PM Reply With Quote
Does anyone have any close up shots of the mountings for the sierra column?
I am more interested in the lower one really and how the bearing is mounted / supported?
Thanks,
Dan
[Edited on 6/12/08 by dubstar_04]
big_wasa
posted on 6/12/08 at 05:37 PM Reply With Quote
pic
dubstar_04
posted on 6/12/08 at 05:50 PM Reply With Quote
wow that looks great, thanks.
Do you have any from the other end?
I am trying to decide how to support the bearing.
Thanks,
Dan
gavin174
posted on 6/12/08 at 06:14 PM Reply With Quote
i have used a replacement bearing that was about £20...
much more positive than the standard one..
a link from robin hood owners club
http://nw.rhocar.org/supporting_the_steering_shaft.htm
part no is SLFL25 not 2S as stated
[Edited on 6/12/08 by gavin174]
chris_smith
posted on 6/12/08 at 07:01 PM Reply With Quote
hi dubstar iv got one of the following kicking around i can forward to you if needed
cheers
chris
dubstar_04
posted on 6/12/08 at 08:20 PM Reply With Quote
Thanks for this. It looks like it could really help!!
procomp
posted on 7/12/08 at 03:46 PM Reply With Quote
Hi Dan.
It might be worth considering that you WILL hopefully have the extra chassis member from the outer chassis rail to the inner intermediate cross member on your race chassis. This provides an excellent opportunity to mount the column 100% firmly to the chassis.
Sorry no pics of the arrangement but if you want U2U me and i will do a drawing of the fabricated mount that will fit this aplication.
Cheers Matt
Ps on the race car DO NOT take the column through the front bulkhead. Mount the column above the bulkhead. Gives a much better angle for the column. And leaves the required room around the pedals to set them up and generally dance your feet.
As per big_wasa's front mounting mounting above.
[Edited on 7/12/08 by procomp]
New Topic New Reply
