chris-p-duck
| posted on 9/12/08 at 09:01 PM |
Brake line fittings
Hi all,
I am about to start the routing and sorting of my brake pipes and am trying to find out what size unions/fittings I need. I have got a westfield
master cylinder and am using the standard ford sierra calipers and drums and have a roll of the standard copper pipe from CBS.
Does anyone know the size and thread I need for these fittings to join the pipes to the master cylinder and then to the calipers (via flexi
pipes)??
Apologies if this is a bit vague and rambling.........
Chris
dnmalc
| posted on 9/12/08 at 09:17 PM |
the fitting on the later sierras are M10. I would change the brake pipe to cupro nikle as the copper will work harden and can crack.
splitrivet
| posted on 10/12/08 at 12:43 AM |
Ye olde copper brake line myth, ah yes I remember it well.
Your perfectly OK with copper brake line its to BS standard.
Bob
