alistairolsen
| posted on 11/12/08 at 02:42 PM |
camber adjusters - any pics?
Been looking at camber adjustment. If you just run a welded in threaded tube then youre restricted to full turns of the drag link, or ~1mm changes.
Ive been looking at these:
http://www.rallydesign.co.uk/images/DAR013.JPG
Im guessing the drag link screws into these,these sit thru a tube int he wishbone with the hex inwards and a nut on the draglink to lock them?
Anyone got any pics of them in situ?
cheers
matt_claydon
| posted on 11/12/08 at 02:53 PM |
From Hellfire's site:
BillHoll
| posted on 11/12/08 at 03:10 PM |
MNR are listing some for a buy it now price of £5 on ebay.
http://cgi.ebay.co.uk/locost-camber-adjusters_W0QQitemZ220324311491QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item220324311491&_trk
sid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
jabbahutt
| posted on 11/12/08 at 03:48 PM |
sorry to hijack but i'm interested in fitting these to my Indy as well. Am I correct that the insert will fit inside the threaded standard
wishbone with no mods or do you need different top wishbones to use this kind of set up?
Nigel
Daddylonglegs
| posted on 11/12/08 at 03:55 PM |
Nigel
Beat me too it
My question too...
JB
alistairolsen
As I thought, sorry for the rubbish explanation! Looks like a much better alternative than the welded boses! Will order some asap
BillHoll
| posted on 11/12/08 at 04:08 PM |
You can either use new wishbones, or if you have enough wall thickness you can have the threads bored out. From memory the adjusters are about 21 -
22mm diameter.
Richard Quinn
| posted on 11/12/08 at 04:10 PM |
Nigel
I don't see how that could be possible but I would love to be proved wrong!
| posted on 11/12/08 at 05:02 PM |
Nigel
If you think about it it would be somewhat tricky to get much material between a M18 male thread and an M18 female thread! The wishbones have to be
made specifically for these adjusters.
[Edited on 11/12/08 by MikeRJ]
| posted on 11/12/08 at 05:22 PM |
Nigel
Nigel,
You'd need new top wishbones with a larger dia and unthreaded tube for the adjuster and drag link to fit into.
Not sure if MK supply suitable parts, but GTS certainly used to supply the wishbones and adjusters shown on Hellfire's car above.
[Edited on 11/12/08 by nick205]
mad-butcher
| posted on 11/12/08 at 08:19 PM |
What I think we all want is something like hellfire had made ( not my place to name the manufacturer ) camber and caster adjustable.
I believe mac1 do a set for about a £100
| posted on 16/12/08 at 08:54 PM |
You know I think you might be right
hellbent345
| posted on 20/12/08 at 10:34 AM |
does anyone have any pics on how the caster adjustment is achieved on hellfires? it looks rather more sophisticated than a few spacers if you get my
drift!
