Author: Subject: Flexy hose to caliper joint?
Bluemoon
posted on 14/12/08 at 10:58 AM Reply With Quote
Hi all,
I have some braided hoses as supplied by MK sports cars. Do I need a (domed) shaped (dowty?) copper washer to fit on the end of the the hose fitting and caliper (i.e so the seal is Steel caliper - copper - Steel hose fitting, with the domed copper washer inside the caliper body)?
Or can I just go Steel caliper - Steel hose fitting? I think this is how the donner was?
Dab
[Edited on 14/12/08 by Bluemoon]
mistergrumpy
posted on 14/12/08 at 11:08 AM Reply With Quote
You've just asked the same question as me and you've already answered mine below! My answer now would be that the front calipers have a slight circular recess around the hole for the brake hose. I went to the brake shop and asked if he had any copper washers for this and he came up with them. They fit this recess perfectly so I would say yes, use them.
The standard Sierra pipes didn't have them I don't think but I think that the hoses had a convex end so that it mated face - to - face with the concave thread in the caliper.
Bluemoon
posted on 14/12/08 at 11:18 AM Reply With Quote
Not quite (I think); Need to put this more clearly is the correct way:
1) Convex Steel Hose - shaped copper washer inside caliper (i.e down hole) - Concave caliper body.
Or
2) Convex Steel Hose fitting - Concave Caliper body..
i.e. not on the out side of the caliper, I think this machined surface is for a bango type hose fitting, and then you use a flat copper washer?
Dan
mistergrumpy
posted on 14/12/08 at 11:23 AM Reply With Quote
Ah I see. You're wanting to put something down the hole first and seal against that. I'd have to say no as you risk blocking the actual brake channel/hole itself. Plus the copper might splinter/shave as you screw the hose against it leaving the filings floating around.
Bluemoon
posted on 14/12/08 at 11:26 AM Reply With Quote
Yep, that why I ask, as steel/steel joint seems a bad idea, in my mind I think I have seen a shaped washer that is designed to go down the hole.. But my mind might be playing tricks on me!
Dan
Bluemoon
posted on 14/12/08 at 11:39 AM Reply With Quote
O.k they do exist, called a conical seal.. Bit I think you only need one if the matting surfaces are damaged?
Dan
Dusty
posted on 14/12/08 at 11:51 AM Reply With Quote
All the bleed nipples are tapered steel on steel round the car. Pretty sure the flexi to caliper joint is designed the same.
Bluemoon
posted on 14/12/08 at 09:45 PM Reply With Quote
Hi Dusty have to agree.. Just going to fit the flexy directly not going to worry about it unless I have a leak latter.
Dan
mistergrumpy
posted on 14/12/08 at 10:00 PM Reply With Quote
I've just done this this morning and I checked an hour ago and I've no leaks.
