prawnabie
| posted on 15/12/08 at 08:10 PM |
Shock absorber bolts
Hi guys
Just had my gaz coilovers delivered off dampertech- had them fitted with rose joints.
The joints are 1/2". I have plenty of 12mm HT machine bolts to do the job, but I will have to order in 1/2" if the are the only ones to do
the job.
What do you use? Is it imperative that I use the imperial or will 12mm do?
Shaun
nib1980
| posted on 15/12/08 at 08:22 PM |
If it's imperial you should use imperial, suspension and brakes need to be perfect, or you'll only regret it for the sake of a £1.50 bolt.
twybrow
| posted on 15/12/08 at 08:32 PM |
My shocks are GAZ. I rang them, and they put a whole bag of sleeves in the post, to convert from 12mm to 1/2".... Might be worth a try!
maartenromijn
| posted on 15/12/08 at 10:15 PM |
When I ordered my Gaz dampers from Dave at Dampertech I told him I wanted to use M12. So he includeded the sleeves without extra charge.
top service.
BLOG: http://thunderroad-super7.blogspot.com/
simonk
| posted on 16/12/08 at 12:51 PM |
Echo that, got a nice parcel of tubular shims from Gaz to sleeve down to 12mm
Simon
