Author: Subject: hellfire! and anyone who knows about front suspension!
hellbent345
posted on 22/12/08 at 05:37 PM Reply With Quote
specifically to you hellfire, what rose joints are you using on your front suspension - top wishbone to car links (ie you specially made caster adjustment) and how does the caster arrangement function on yours, and do you have any close up pictures of the adjustment system and rose joints? anybody else know of good rose joints to use on the old front wishbones?
thanks al
blakep82
posted on 22/12/08 at 05:40 PM Reply With Quote
my car uses 5/8" rod ends, with 1/2" holes for the bolts.
1/2" would be the minimum to use for suspension i'd say
________________________
posted on 22/12/08 at 06:57 PM Reply With Quote
We purchased our rose joints from McGill Motorsports. I've got the order details at work, so I'll dig em out tomorrow and let you know the specs. Castor is set by spacing the top wishbone within the bracket and can be fine tuned by adjusting the individual rose joint.
Phil
[img][/img]
posted on 23/12/08 at 09:26 AM Reply With Quote
Steve/Phil,
Have you spent much time setting the car up yet with the new bones?
Any notable improvements or issues?
Also, have you left the lower bones standard?
posted on 23/12/08 at 10:34 AM Reply With Quote
Rose joints are M12 ultra high performance.
Nick, the lower bones are standard. TBH, other than trying various castor angles to see what effect it has, we haven't had chance to do much else. Hopefully if/when the weather picks up we'll be able to get out in it and play around some more.
Phil
jabbahutt
posted on 23/12/08 at 11:37 AM Reply With Quote
where did you source the top wishbone from to allow you to use the rose joints and camber compensation set up?
Nigel
posted on 23/12/08 at 12:14 PM Reply With Quote
Top wishbones are MK Sportscars but we chopped and modified them to incorporate the camber adjuster and rose joints for castor.
Phil
Antnicuk
posted on 1/1/09 at 11:21 PM Reply With Quote
i am fitting rod ends to my lower wishbones to be able to adjust the castor, what method did you use to get the castor roughly right?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
